N1MM CW DDutil and PowerSDR
Andrew O'Brien
Member ✭✭✭
Can someone post details of your set-up for using N1MM in CW contests using PowerSDR 2.7.2 with DDutil involved (so I can also add Cw Skimmer). It is normally easy to set up PowerSDR, DDutil and other applications using DDutil's RCPs but I can't get N1MM to actually send CW. I had it working fine in earlier versions of PowerSDR . I suspect I am screwing up the PowerSDR PTT port settings and the corresponding area in N1MM configuration area .
<edit> Apologies, I answered for SmartSDR - Stan
At this moment, without using some external device, the 6x00 will not process CW via a COM port. It will trigger the PTT but will not produce RF output.
I'm waiting for a release beyond current V1.1.3 before completing N1MM automation. Wishfully well before FD 2014 but that doesn't leave much time after 1.2 potential release.
Had me worried for a moment, I assume PowerSDR can do it.0
I have the issue solved now.0
A video showing how i set mine up https://www.youtube.com/watch?v=jBYGZLbP1xA0
- 685 The Flea Market
