DAX won't transmit sometimes
Drax
I keep having an issue where WSJT-X will key the radio, I hear the relay click, and I see the Level meter moving, but the RF Power meter is not moving and the panadapter shows no RF output.
When I click TUNE in SmartSDR the radio is able to TX full power. Clicking tune in WSJT only causes the Level meter to rise to a steady level and the relays to click on.
This often happens spontaneously after I've had the radio running fine and after sometime it stops working. Then I have to remove power from the radio and reboot it. And sometimes that does not work easily.
What am I missing?
What am I missing?
2
Drax,
I also use WSJT-X a lot with my 6700. I have experienced the "no RF" problem that you described and it has been because the DAX button on the Transmit Control Panel has not been selected after a restart of the 6700. It would be nice if this was part of "persistence".
I understand that this is not the only situation where you experience no RF power. I too had that same experience until I upgraded to v. 1.1.3...are you running the latest upgrade?
Ed, K0KC
Ed - the DAX TX button persistence issue will be addressed in SmartSDR v1.20
Tim,
Great!...my old brain needs all of the help it can get!
Ed, K0KC
I have newest version and I've checked that DAX button. There's some other gremlin there too though.0
I also see this at times with my 6700. I usually rcv on stream1 and xmit on stream2; I have gone several weeks where stream2 has just worked.... This morning its back to no output on stream 2, so I switch to stream3, enable it in the control panel, switch it in wsjt-x and things work... still some dax gremlins in there..
I have found, occasionally, that shutdown issues require me to stop DAX and restart it before things work right. That is usually my first recourse when things get fouled up.0
- 419 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
