Spurious "eq apf" status message emitted from the radio
Stu Phillips - K6TU
Stu Phillips - K6TU Member ✭✭
edited May 2020 in SmartSDR API
Just to make sure this gets a DE... for cleanup post moving APF to be per slice, a spurious "eq apf" message is emitted from the radio after sending a "eq rx info"...
Low priority, I added code in the meantime to pitch it...
Stu K6TU
