Slice/CAT Issue
N4TTY
I had created 3 slices, Slice A was set for DIGU with DAX Channel 1 both for transmit and receive. Slice A was talking to FLDigi. And CAT was working fine. Slice B was set for a CW Net frequency. Slice C was set to SSB and a freq in the same band as Slice A. When I shutdown and then came back to PowerSDR the next time I found that Slice A and C had reversed and while FLDigi was working fine as far as the DAX Audio channels were concerned, the CAT commands were still associated with Slice A. Therefore frequency changes on Slice A were reflected in the frequency display of FLDigi even though the audio channels were being controlled by Slice C.
Had to delete all the slices and re-establish Slice A as the DAX/CAT pair, and set Slice A back to the SSB channel.
- 117 Aurora
- 323 Shack Infrastructure
- 228 Networking
