Averaging method and settings per Panadapter
Al_NN4ZZ
Al_NN4ZZ Member ✭✭✭
edited June 2020 in New Ideas
I think it would be really nice to control the averaging parameters on a "per panadapter" basis.  That way we could do a side by side comparison of the averaging method/settings to decide which we like best.  You might decide to use both methods (old and new) or have different settings for a given method  for different modes, bands, or conditions.
The new method (V1.1) seems better in some cases with weak signals and the old method (V1.0.24) seems better in general use.   But I'm not even sure of that since it's not possible to do a real time comparison.
Providing options is more work but probably the only way to make everyone happy.  The questions are:
- how much time will it take
- is it worth the effort (i.e. how many PLUSes did the idea get?)
- where does it fall on the priorities list.
Greg, Michael and others -- What do you think? Is it worth the effort?
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
3 votes
Open for Comments · Last Updated
  • Michael - N5TGL
    Michael - N5TGL Member ✭✭
    edited December 2016
    Well, it sounds to me like the change was very simple...just an adjustment of the attack/decay settings for the averaging function.  Ideally, I'd like to see those settings exposed to the end user so they can tailor the response to what they would like to see.
    However, I'd be happy with a switch selection to go back to the 1.0.24 and the 1.1 method if I had no other choice.
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    (Copied by author from response on initial post...)
    I guess it depends upon which parameter you want to average.  Are you wanting to average the total signal?  The attack times?  The decay times?  Just smooth out the total display?  I see about four different parameters that can be adjusted.  Attack time, hold, decay time, and time frame to average, perhaps more.... Frankly, I like the new display, once I got adjusted to it.  But I would support porting these parameters to some sort of "properties" tab, along with adjustments for many other functions, such as NB, NR, ANF, APF, etc.
    Eventually, I am sure that they will do this.  The first task is to get these functions functional.  Then add the bells and whistles and tweak-ability....
  • Michael - N5TGL
    My "gold standard" is how PSDR (not SSDR) looks with 30 FPS and the average switch on.  That's the display that looks good to me, and what I've gotten used to over the years.  I did like the 1.0.24 improvement of an averaging slider that allows tailoring to personal taste.  I do not like the fast attack/slow decay of 1.1, as it is visually tiring to look at, although not as bad as the "raw electric arc" display of the previous un-averaged releases of SSDR.  Yeesh, that was **** the ol' eyeballs.  I really don't want to watch a jumpy display.
    You comments remind me of the old ADSR (Attack, Decay, Sustain, Release) synthesizers, although I'm not sure if the entire ADSR envelope would be useful.  I think just being able to change the attack and decay would offer plenty of customization for any user.
    The "cherry on top" would be having a set of maybe 4 user-programmable presets that could be selected as conditions warrant.
  • Ned K1NJ
    Ned K1NJ Member ✭✭
    edited February 2017
         Yes, I agree with Michael.  In addition, on 160 and 80 here with some impulsive noise, I find
    myself using the 5000.  The SSDR display jumps a lot, and the NB in SSDR doesn't reduce the
    audible pop or the very nervous display.  The 5000 just completely eliminates both with the
    combination of averaging and the NB.
    Ned,  K1NJ
  • Steve-N5AC
    Steve-N5AC Community Manager admin
    Couple of things: The change to the averaging is very simple and we can provide an option if that's desired.  Today NB is done in slice receivers and not in the panadapter data so the display will show you actual noise while the slice receiver will filter it with the NB.  We're considering adding NB to the display as well -- we have a couple of customers that need it badly because of their local noise issues that are non-stop.
  • Ken - NM9P
    Thanks, Steve, I would love to see all of the above as user-configurable options.
  • Michael - N5TGL
    edited October 2016
    I would definitely like to see the option for averaging method -- or a couple of sliders to adjust attack/decay, which should keep just about everyone happy I think.
    As for the NB in the slice vs. in the panadapter, I was wondering if you could clear something up for me.  Since the NB is "in the slice" does that mean that nearby strong stations outside of the slice do not cause "NB pumping" with those strong signals?  If so, that's a very valuable feature I would not like to lose.  I would then also assume that NB in the panadapter would be affected by all strong signals in the pan, which would make the NB behave much like every other radio on the market, but I can also see the advantage of having a whole-pan NB to see signals.  At my previous QTH, (with my 5000) I would get tons of noise on 20m at night, but with the NB, it would clean it up so I could actually see on the panafall what was out there.  However, strong signals would make the NB less effective, as we all know.
    So, here we go again with the options!  :)  Please keep the slice NB for the (I presume) insensitivity to nearby strong signals.  Add the option of a whole-pan NB so folks can see signals hidden in the noise.
