New SmartCAT not installed!
iz7auh
Member ✭✭✭
Need help,
I unistal SmartCAT and old SmartSDR after reboot I have installated new SmartSDR 1.1 and then a new release of SmartCAT but I have problem to instal installation wizard ask me an error looking image, I using Windows 8.0 Pro x64
I make few reboot and new installation but no solution on my problem
Francesco Hi,I also had this problem. Launch the SmartSDR Cat installation setup again.
Watch for the popup asking for your okay to install the Bronze Bear Driver and click Ok. You need to do this before the setup program times out. The error you got is because you didn't click on okay to install driver fast enough. Note the popup may be underneath the setup program so try moving the setup window to be sure you don't miss it.
The will be one more pop up you need to click okay on then everything will be installed correctly.
GL & 73,
- Bob, W1RE
I get this error all the time on my Win 8 system and I click on the OK to trust bronze bear very quickly.
It does not happen to my Win 7 systems.
- 690 The Flea Market
- 461 SmartSDR for Mac
- 112 Aurora
- 976 Genius Products
- 322 Shack Infrastructure
- 227 Networking
- 146 Contesting
