GPS Not working All Zeros
Drax
Drax Member
edited October 2019 in SmartSDR for Windows
My GPS tab has all zeros for the lat.,long, etc. So I aquired a PCTEL GPS-TMG-HR-26N antenna and installed it outside. The GPS tab still has all zeros. The antenna requires a 5v bias voltage. I measured across the radio's GPS connector with a volt meter and there's no voltage there. How do I enable the bias voltage or measure it correctly? Is there a way to get more status of what's actually happening with the GPS module? I never see any color codes other than solid amber or solid green. Some GPS receivers actually let you see what if any sats are being seen to at least let you know that the antenna is working. Clicking the Install button does nothing.
  • Drax
    Drax Member
    edited January 2014
  • Drax
    Drax Member
    edited January 2014
    The GPS Installation: line is blank too.
  • Ernest - W4EG
    Ernest - W4EG Member ✭✭
    edited October 2019
    I will just ask the obvious questions. Is the antenna in the open and able to see south; assuming you are in the northern hemisphere since you do not list your call sign. It takes time to acquire the satellite. Here is my GPS antenna on top of my computer; facing south.
  • Drax
    Drax Member
    edited March 2017
    KB3X I'm in the USA. South is clearly visible. I've have about a 50 ft. run of LMR-400 to get it out away from the house. I get a perfect GPS signal on my iPhone right beside the antenna. I'm concerned because I cannot read any voltage on the radio's connector. There should be 3 to 5v on it, I'd think.
    edited December 2016
    The radio does not think you have a GPS installed. What happens when you click on the Install button?
  • Drax
    Drax Member
    edited January 2014
    Nothing seemingly happens when I click Install. Then after awhile it loses connection to the radio. Are there install instructions for the GPSDO I can look at and compare mine to? It was factory installed.
    edited March 2017
    That is not behaving correctly. We need to dig into this further. I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
