Stickey Antenna Switch revisited with further problems
Robin Haighton
I find that after using higher frequency bands Such as 17M on antenna 1, then using 80 M on antenna 2 the antenna relays keep the TX on Antenna 2 when I return the receiver to Antenna 1. I have proven this by putting meters in both antenna lines firstly, using 17 M on ant 1, then changing to 80 M on ant 2, making a contact, and reselecting 17 M.If I now try and tune the 7600(either the tune button or ant tuner) I see power going to ant 2 but no power going to ant 1. Also if I try and Transmit, using PTT, the power goes to ant 2 but the receiver is still active on ant 1 (17 M). I can correct this by shutting down the 7600, and re starting and calibrating, but even then I have to press "Loop A" (or loop
button twice for full functionality. I have repeated the test several times to prove that this is so. I think it is a software problem not a Hardware one ..... your comments please Robin Haighton VE3FRH
Another way of reverting back to the correct antenna is to click on the RED ant1 , the select ant 2 then reselect ant 1, now both RX and TX are on the same ant 1 Robin Haighton VE3FRH0
This stickiness is still a problem on the RX only port selection also. At least on my 6700. Another thing that happens when selecting between the RXa and RXb antennas (No Band change or anything else being done... just RX antenna selection) is the preamp settings revert back to the normal position. Not every time however but most of the time. Hopefully all this will be addressed on Ver 1.1 as I am using the Beta 1.0.24 now. Looking forward to the next couple weeks and having a new radio.0
Hi Larry, my original comments about a sticky switch were made using only one antenna port, with an antenna selector switch, but now I have my 80 m delta loop connected to antenna port 2, this is when I first noted that on returning to17 m on ant 1 (from 80m) I could receive, but not transmit. investigation showed that although the receiver had returned to 17m on ant 1, the transmitter was still connected to ant 2 , but the frequency was 17 m. At first I thought the problem was in my linear amp, but after applying watt meters to each out put from the 7600, it clearly showed that the Tx was not changing back to ant 1 Like you I hope this might be rectified in V 1.1 Robin Haighton VE3FRH0
This issue is slated to be fixed in SmartSDR v1.10
Thanks for the info,Tim. At first I thought my linear amp (connected to Ant 1) had failed until I found the TX power was still going to ant 2 73 Robin Haighton VE3FRH.0
- 696 The Flea Market
- 121 Aurora
