side by side pans?
W5XZ - dan
W5XZ - dan Member ✭✭
edited June 2019 in SmartSDR for Windows
seems like i have seen a screen shot or two with 2 panadapters, side by side, instead of high and low. how is that done, please? 73, w5xz, dan
  • Jim Bryce W5HFS
    Jim Bryce W5HFS Member ✭✭
    edited June 2019
    If you have 4 pans up click on the square in the upper right of one to "maximize" it. This will make it fill most of the top of the screen and put the other three side by side below. There are probably other ways, but this is what I've used.
  • W5XZ - dan
    edited December 2016
    so, it's just a '6700 thing' right now, i guess? tnx, jim
  • Jim Bryce W5HFS
    edited June 2019
    I don't know, since I'm using a 6700. You may find a way to move the windows around like the settings panel that is usually on the right.
  • W5XZ - dan
    ok, now i'm REALLY REALLY looking fwd to 1.1 with my 6500, ha!
  • Al_NN4ZZ
    Al_NN4ZZ Member ✭✭✭
    edited June 2019
    Dan, I noticed it will switch if you adjust the window size. Here is a video with only 2 panadapters open. http://youtu.be/rLTOTDd5msE Probably other ways too, it seems to be automatic based on window size and number of pans open. Regards, Al / NN4ZZ
  • W5XZ - dan
    hey, cool Al !! tt works! I notice i have to turn off the Tx panel...
  • W5XZ - dan
    now, with two maxed out pans, i can see 1 to 28 Mhz !! kewl !!
  • Robert -- N5IKD
    Robert -- N5IKD Member ✭✭
    edited June 2019
    I works with the TX panel, but only one panel of the TX panel is usable at a time.
  • W5XZ - dan
    right-o, robt. tnx
