SmartSDR Crashes when I try to use RIT when running SoDiRa DRM Program
Ken - NM9P
Member ✭✭✭
While tuning stations with SoDiRa running through DAX, if I hit the AUX1 button and try to fine tune with RIT, the SmartSDR crashes the moment I try it. I have replicated it several times after a total Cold Boot Factory reset. I am running a 6500 with SSDR 1.0.24 and the CAT and DAX programs that came with it. Have FlexControl Knob installed on port 31 Running Windows 8.1 on a Lenovo Ideacentre K410 with 6 GB RAM, i3 processor and dual monitors - one 22" HDMI, and a 23" through the VGA port. I wonder what is causing this? BTW, Once I figured it out, If I don't try to use RIT, the program works well, decoding DRM and also AM & FM signals. The readability of the AM detector is actually better than the one in the 6500, which has a very low audio. (I get more readable audio on the 6500's own detector after carefully adjusting the gain and AGC with the AGC turned OFF.)
Ken, Is this happening on the FlexControl that is malfunctioning?0
Yes, but before it broke. And only when using that program. RIT worked ok otherwise.0
- 692 The Flea Market
- 119 Aurora
