Undocking equalizer pane
Greg
This was closed as Solved but I don't think it is solved it all. I was running this on a 13 inch laptop and Lenovo yoga and it seems like that it should be able to display the full smart SDR display. If not then you should be able to accommodate moving modules around so that they are visible. saying that the display is not large enough does not make sense. If this is the case, then what is the minimum size display necessary to utilize the full smart SDR.
Greg, As of now, you can not resize the individual panes in the TX submenu, but you can rearrange them and by click and drag the top Darker brown bar. So if you need the equalizer move the VOX down and that should move the EQ window where the VOX window used to be..0
- 693 The Flea Market
