Selecting 2M shuts down the 6700
Stan VA7NF
Member ✭✭✭
As previously reported I have had a similar 2M reset problem on a 6700 that was "corrected" by a radio reset. There were NO other applications involved, only the 6700 and SSDR. Version Beta V1.0.24 Other symptoms around the same time: The panadapter extended to double the upper limit A reverse image of the spectrum appeared with the broadcast band up around 300Mhz. Shortly after this selecting the 2M band did a radio/network reset. Nope: Stu's application may trigger it but is not the cause. It may be a good tool to help diagnose the real problem.
- 198 SmartSDR+
- 323 Shack Infrastructure
- 228 Networking
