Headset into my computer and DAX, Remote DAX audio
K2CM
K2CM Member ✭✭
1. Once I get the F6.7K audio into my computer, how do I get the audio in/out on my USB headset? 2. Once I get the F6.7K audio into my computer, how do I get it to Remote Desktop? I am able to "Remote Desktop" into my F6.7K computer. I can operate the radio without issue; however, I cannot get the audio to/from remote desktop. I am able to hear audio from "Spotify" at the remote computer.
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    I haven't tried it yet, but you might try Audio Repeater, which came with the Virtual Audio Cable. You can set it to repeat the DAX out to the Headphones, and set up another one to send the USB mike to the DAX IN to the radio, using the DAX Control Panel.
  • K2CM
    K2CM Member ✭✭
    edited September 2019
    Will give that a try.
  • K2CM
    K2CM Member ✭✭
    That works quite well! Now I have to figure out how to get the audio into remote desktop.
  • Ken - NM9P
    Use the same trick. Install VAC, on remote desktop and use Audio Repeater, linked to DAX... If you are referring to off site desktop, you might try teamviewer or Skype for audio. You can link Skype mike input to the DAX or Audio Repeater ....
