CAT program not seeing ports
Paul
Same problem here. Version 1.2.2.0 running with 1.0.24.22 SmartSDR0
I have the same problem as noted in an earlier post. running the latest beta0
I have worked on this with many installs and uninstalls and reboots and CAT does not work anymore. I show Flex vitual port 4/14 in device manager but CAt does not show comport for third party programs after all the work!0
Yes, I reported this problem earlier.0
I went back to version 1 and all is working just fine now. not sure what happens in the beta but this version is working great! Problem solved albeit a former version0
Today deleted version 1 and reinstalled the beta 3 times before it all came together and worked! so, no more problems0
To solve this issue, just delete Smart CAT and re-install it. Delete any and ALL CAT off your computer desk top. If you try to do a fix CAT; that does not do it either. I have become an expert in this area: HRD force me to do this several times.0
- 997 Maestro
