CW Keying the FLEX using DAX
W4EY
General question. Is there anyway to use a Hand/Paddle Key to send CW from the FLEX using either the CAT Shared, Dedicated port or a DAX line. Fldigi will key the FLEX with CW Macros when the FLEX is set to operate USB. This seems to work for sending predefined CW macros. If the FLEX is set for CW Mode operation, Fldigi will key the radio with PTT. However, in USB Mode I loose any capability to use the Hand Key/Paddle directly plugged in the FLEX. Also, loose capability for using the keyboard for CW OPERATION. Technically, I hope this is not a DUMB question. I am just trying to operate the FLEX in CW Mode using Predefined CW words (Macros) for supporting software like Fldigi, .
