Loss of Audio when QSY'ing via CAT
K9DUR
Found a repeatable bug in v1.0.24. Radio is a 6700. 1. Pick a band, any band, & set up to operate split. (Open two slices (A &
with TX on slice B.) 2. In your favorite logging program (I am using DXLabs), click on a spot of a station working non-split on a different band so that you QSY via CAT command. 3. Panadapter goes to new band/frequency/mode. But, oops, you forgot to close slice B, so WIDE indicator is on. 4. Double-click on slice B indicator at edge of screen to go back to slice B. 5. Close slice B. Panadapter goes back to slice A, but there is no receive audio! Changing to a different mode & back again will restore audio. 73, Ray, K9DUR
