Troubleshooting WiFi to Flex-6000 series connectivity issues
Stu Phillips - K6TU
Stu Phillips - K6TU Member ✭✭
edited August 2016 in New Ideas
In the hope that this saves others some time... There are WiFi products in the market that describe themselves as "WIFI Routers" - the default configuration of some of these creates a SEPARATE subnet for devices connected wirelessly to your network. If your Flex-6000 series radio is plugged into the "wired" or Internet side of your network, you may not be able to access the radio FROM the wireless network - for example, from a laptop running SmartSDR or from the K6TU Control iPad application. The WIFI Router can also operate as a WiFi Access Point which will have all your Wireless and wired devices on a single network. So in the event you are having problems seeing the radio from a wireless device, this is one of the first things to check! FYI! Stu K6TU
0 votes
In Review · Last Updated
