A simple way to listen the DAX transmitted audio
Beppe IK3VIG
Hi, DAX is a wonderful addition to SSDR, more again when the TX MON will be available by default. A simple way to listen the DAX TX channel at today is the use of "Audio Repeater" function included in Virtual Audio Cable (I think most of us have it installed in the PC again). - choose Audio Repeater from VAC folder - select the DAX TX channel are you using with your digital software (fldigi or other) in device drop down menu as device to listen, - select the audio device where you want listen (Windows sound mapper) - press start. When you transmit (PSK - RTTY - ecc ecc) your TX signal will be reproduced by your PC audio system. 73 Beppe ik3vig woodboxradio
Hey Beppe, that is really slick! Thanks a lot. I never would have thought of that one. 73 de Ken - NM9P0
any way to get around the 5 sec delay?0
- 692 The Flea Market
- 119 Aurora
