CTASIO error popup message on startup of powersdr v2.7.2 when VAC enabled
kc8zul
Error message box at startup CTASIO. PowerSDR v2.7.2, when I enable a VAC with standard defaults I get this message on startup the error box says "there are no creative audio products ...". The VAC works and I get audio routed to the PC's audio out. I am running Vista with all the updates. Clicking ok in the error block allows proper operation but it doesn't happen on other systems and it is a pain in the ****.
Windows only allows one ASIO audio driver to be loaded at one time. Looks like at one time you had a Creative Audio sound card with an ASIO diver loaded and now it is complaining. This happens if the CA was not fully unloaded. Try this: Go to C:windowssystem32 Look for ctasio.dll rename it to ctasio.dll.old Restart windows0
- 692 The Flea Market
- 119 Aurora
