RX slice persistance no longer working
N4AB
N4AB Member ✭✭
edited November 2017 in SmartSDR for Windows
Persistance was working on my 6700, under V 1.0.24 but now the RX slice no longer shows up when I boot up from a cold start. Band and display information is still working. I have been working on a DAX problem and have uninstalled and reinstalled many times since last weeks release. Has anyone else had this problem? I will try another reinstall. Al N4AB
  • iz7auh
    iz7auh Member ✭✭✭
    edited March 2014
    Also I have noticed some problem with that but I have not figured out if this is a bug or am I wrong in something, it would be an interesting feature to reset the persistence
  • Al K0VM
    Al K0VM Member ✭✭✭
    When everything starts to seem strange with persistance, and it is really causing a problem... First try... rebooting the radio if that does not help Second.. Shut dow the radio, turn of the power to the radio for a minute or two, Reboot the PC. Restart the radio with a reset to factory defaults ( Hold down the OK button then push the start button, release to OK then release the start ) It should have forgotten everything by now.. AL, K0VM
