Audio level drops when using DAX
Paul
Paul Member
edited January 2020 in DAX
Audio level drops when using DAX. Flex 6500, SDR 1.024, win 7, Intel Duo 2.33, 64 bit, 16 gig ram. When I have slice A set to use DAX and slice B to any other mode the audio level on both slices drops, it does not change received signal level, toggling slice A from DAX to another mode does the same to audio level, USB, LSB, etc. the audio level comes back up, switch back to DAX the audio level drops.
  • DonS
    DonS Member ✭✭✭
    edited January 2020
    What I noticed was if in digi mode with DAX enabled and I disable the TX in the slice the audio comes up and when I enable the TX in the slice the goes down though there is no change in the signal level on the meter. I am only using a single slice at the moment with the 6700, iMAC with Parallels , win 7 Pro and assigned 4gb of ram to the vm.
