Issues adding Panadapter
Robert -- N5IKD
I have a few issues when adding panadapters: 1. The slice with DAX1 selected goes to no DAX selected and a new slice gets the DAX1 setting. 2. The new slice shows up on the existing panadapter, and the new panadapter has no slice. 3. When slice A on the first panadapter is set to DAX1 and I change bands on the second panadapter where slice B DAX is set to none, then DAX on slice A goes to none and the DAX on slice B goes to DAX1.
3
Robert what radio model are you using?0
67000
This reply was created from a merged topic originally titled The invisible slice and other observations on 1.0.24. After shutting down SmartSDR (running PSK31 on 20 m) and restarting, there is no slice visible. It's there, working, the log program sees it, but not visible. And no clicking dragging, or tugging gets it back. Switching to a different band then back to 20m and the slice reappears right where it was. This is repeatable in my case.
Have also noticed sometimes there is no audio when going to DAX mode - even though it was just working fine and no changes made. Found toggling both the #1 and TX in the DAX control panel would restore it every time.
The previous problem with SmartMeter not functioning is solved with new CAT.
Kudos to Flex for this new version!! Loving the DAX!0 -
This looks like a persistence issue that we have previously identified and should be addressed in the next released version of SmartSDR.0
- 688 The Flea Market
- 105 Aurora
