No Audio on 20M with upgrade.
Nick
No audio on 20M. Everything works on other bands. Removed power, restarted computer, still no audio on 20. At full volume can hear a hum. Will check again tomorrow when there is activity on the band but should hear some noise.
I have checked each band including 20 meters and wwv audio on recieve and transmit except no transmit in wwv of course.0
Had similar issue - resolved by "wiggling" the sliders (audio and AGC). There still seems to be a little bug in there that has them forget their values in certain circumstances.0
Also make sure that you do not have mute on that slice or the AGC-T all the way down too. Did that one my self.0
Wiggled the sliders, Checked the mute button. I can see the signals but no audio. Opened up slice b and it does have audio. looks like I could work split with no problem. Audio is completely dead. No hum or noise at all. Don't see any problem on other bands. Is there a way to force a reinstall on the radio?0
Power the radio off. Press and hold the "OK" button on the front panel when you press the power button to turn on the radio. You will see a resetting to factory defaults message. Release the OK and power button and allow the radio to finish booting up.0
Fixed it. When I change to a different filter width the audio returned and all works well now.0
- 117 Aurora
- 323 Shack Infrastructure
- 228 Networking
