Fan is on High - does not transmit
6700, Fan is on HIGH, no transmit... Receive is deft Turned OFF and ON Same Disconnected the POWER - Same Fan is on HIGH not hot, have/was not transmitting when this occurred... KD6LAY dallday@qnet.com
  • George KF2T
    George KF2T ✭✭✭
    edited February 2019
    Sounds like a job for the Helpdesk, but on the "disconnected the power" step - did you wait several minutes with the power removed before reconnecting it? Can you do a front panel factory reset (holding the OK button while powering up)?
