Help with Macbook Air/parallels win 7 and SSDR/CAT
Reggie-k6xr
Reggie-k6xr ✭✭
edited April 2020 in SmartSDR for Windows
need some help with a new Macbook Air and parallels getting SSDR and Cat working. cat does not create comports to connect to 6500. in the select radio window the 6500 does not show up. I have rebooted the router, restarted all items. Macbook air I7 256GB/8 GB with Paralles 9/win 7. Flex-6500. connection to MB is wi-fi. hopefully someone has been there and did this?
  • Sergey R5AU
    Sergey R5AU ✭✭
    edited April 2017
    Hi Reggie, i'm successefully using iMAC with F6700 (Maverick+Parallels 9.0+Win7 64) and cable network. What is set up Netwotk adapter in Parallels - Bridge/Default/Other ? Have you acces to the other resources from Win7 (ex: Internet) ? In general on you Wi-Fi access point or you router you can see Ip adress of you F6500 (of course if DHCP started), what you can see with ping... command from the Win with adress of the F6500 ?
  • Reggie-k6xr
    Reggie-k6xr ✭✭
    edited April 2020
    Hi Sergey! thanks for the response. Here are my details: network adapter is set to Bridge. I can ping the ip address of the 6500 successfully. the internet works fine. there are flex virtual comports 4-16, 5-15, set up in device manager but SSDR or CAT does not connect to them. there are no comports displayed in CAT.
  • Sergey R5AU
    Sergey R5AU ✭✭
    edited April 2017
    Well Reggie, in case Flex visible into the network, CATSSDR will create pair com4-com14 automatically, user can create an additional if needed. In case this pair ar not crteated or you can't see you TRCVR into SSDR screen at startup, i think you have a issue in the you network - Wi-Fi point, Router etc., pls check IP adress of you MAC and Win - they are in one segment with TRCVR ? i guess they have different allocation with adresses.
  • Reggie-k6xr
    Reggie-k6xr ✭✭
    edited April 2020
    Yes, you are correct. The flex is not visible to this macbook. I have another Macbook and it works in bootcamp as well as my mac-mini running bootcamp. But this macbook with parallels does not. I am not sure what to do now except go to bootcamp with this one as well. It must be on the network as I can ping it from all devices. thanks for your help
  • Sergey R5AU
    Sergey R5AU ✭✭
    edited April 2017
    Reggie, a bit later i will send you a screen from my mac with parallels and setup
  • Keith - AE5XN
    Keith - AE5XN ✭✭
    edited February 2014
    Regie, Changed the virtual network adapter in Parallels from a Shared Network to a Bridged Network, reboot Windows, and then it should find your 6700 just fine. I'm running Parallels 9 with a 2012 Mac Pro here, with Windows 8.1, and it works great. Keith - AE5XN
  • Sergey R5AU
    Sergey R5AU ✭✭
    edited April 2017
    Keith right, in selected menu(properties of the virtual machine) necessary to choose Bridge Network instead Shared Network as i mentioned into first reply, below you can see it(screen on Russian but i guess understandable)
  • Reggie-k6xr
    Reggie-k6xr ✭✭
    edited April 2020
    When i arrive home, i will check above suggestions Thanks
  • Reggie-k6xr
    Reggie-k6xr ✭✭
    edited April 2020
    SUCCESS SUCCESS SUCCESS! thanks to all for help in getting me up and running with my new Macbook Air and Parallels! SSdr and CAt are both running well and I am gratefull to the community for all the help! Many thanks!
  • Keith - AE5XN
    Keith - AE5XN ✭✭
    Reggie, Glad it's working now for you! I knew you'd get it going. So far, I've been very happy with the performance of SSDR 1.05 while running Parallels Desktop 9 with Windows 8.1 64-bit on my 2012 Mac Pro 12-core 2.4GHz. Keith - AE5XN
  • Reggie-k6xr
    Reggie-k6xr ✭✭
    edited April 2020
    thanks for your help!
  • Sergey R5AU
    Sergey R5AU ✭✭
    edited April 2017
    Reggie, glad to hear it, my setup is iMac27 with Maverick, Parallels, Win7 64; SSDR, DDutil, Expert console(with my 2k-fa), Maclogger DX( or N1MM), + flexcontrol, mic- heil781 How the SSDR looks like on my mac: http://m.youtube.com/watch?v=FK82V1g4GTM
  • Reggie-k6xr
    Reggie-k6xr ✭✭
    edited April 2020
    Nice video! I have the 6500 and a Mac-Mini using bootcamp and win7. And this week a new macbook Air 8 GB and 256 GB SSD, 11 inch with parallels and win 7. I use MacloggerDX or DXLabs Suite. Flexcontrol, and Heil Handi-Mic. For CW a Winkey keyer and paddles. I also have a Elecraft KX3 for qrp. thanks for your response and help!
