V1.0.5; Error message when changing BAND without closing RX-A...
k0eoo
Member ✭✭✭
When I first bring up SSDR V1.0.5 and immediately change the band to something other than 20m I get a long error message. This has happened each time I opened SSDR, but only if I don't close RX-A first. If I close RX-A first the band changes normally. In the past I was always able to change bands with RX-A opened; the new band would come up with RX-A opened and ready to go.... Dennis, k0eoo
Please do a screen capture of the long error message so we can use it for debugging.0
Dennis, Unable to duplicate here, When you reopen SSDR, it comes up with the slice pointed at RX A as the receive antenna? TX antenna should still be connected to Ant 1 .0
Hello Tim and Dudley, I was NOT able to reproduce the problem I encountered after I loaded V1.0.5.... I tried multiple times last night to reproduce the failure and I was unsuccessful (good news, some might say). If the error message should ever reappear I will capture and forward it on to Flex.... Dennis, k0eoo1
- 198 SmartSDR+
