SmartSDR Icon availability
Ernest - W4EG
There HAS to be one somewhere in the windows setup, because it uses the icon for the SmartSDR program. SmartSDR CAT has its own Icon also. But my windows skills are rusty enough that I can't remember where they are stored in Win 7/8.1
Thanks Ken, I found the CAT icon but there is no SmartSDR. The CAT icon is in under: Program Files-FlexRadio Systems-SmartSDR CAT-CAT I'll keep on looking for the other one; unless you or anyone else knows.0
My SmartSDR version 1.0.0 "Property" does not have a "shortcut" to "Customize" and "Change Icon" listed. However, I keep a version on a USB device. I found it there. I was skeptical when I found the CAT but not SmartSDR. The only difference between the two is the date downloaded. Issue SOLVED0
The EXECUTABLE wont have a a Customize or Change Icon property in the properties as it is assigned the icon when built. Those selections are only available to a ShortCut or a Folder. The following steps are from Windows 8.1 but the steps are the same on all windows versions. Create a folder...
Bring up the properties
Select Customizes and Select Change Icon - then look for icons in the SmartSDR executable.
Click OK and then Click Apply and voila..
- 117 Aurora
- 323 Shack Infrastructure
- 228 Networking
