RTTY, DxLab and FSK
Brad - N6SPM
Brad - N6SPM Member
Wondering if this is normal behavior, or perhaps I'm setup wrong. When I select a RTTY station in Spot Collector, Commander gets set to "RTTY" mode and sends an "MD6" or FSK command to SSDR (I checked). SSDR responds by going into DIGL regardless of band (e.g. 20m). WinWarbler decodes just fine. In fact, if I configure so it goes into USB, I have to set receive-reverse to decode. I'm just accustomed to USB (or DIGU on Flex) for the digital modes, so I wonder if this is normal. Thanks es 73, Brad - N6SPM
  • Stu Phillips - K6TU
    Stu Phillips - K6TU Member ✭✭
    edited May 2020
    Brad, RTTY is always sent LSB - even on HF bands so the configuration change to DIGI-L is correct. The convention is that the SPACE signal ) for RTTY is sent as the lowest frequency of a pair of tones. The MARK is by convention the highest tone. Stu K6TU
  • Brad - N6SPM
    Brad - N6SPM Member
    edited June 2014
    Thank you Stu. I've not operated much digital so it's a learning experience for me. 73 Brad
