Can Not Select SliceA for xmit
Roger Rockwell/na4rr
Flex 6700 ssdr 1.0 On 10m opened slice on 28.3500 and made contact. Opened another slice down on 28.032. Moved around some on the cw part until I found someone I wanted to call. Select sliceB for xmit. All worked. Panadapter shows Slice A out of view to the right. Double click on the SliceA box and that takes you back to 28.350 but now cannot select xmit for that slice. If I look at the Panadapter it shows SliceB out of view to the left with tx. As I try to select Xmit in Slice A the xmit indicator for B goes away but no xmit for A. I have to x out slice B in order to get slice A to xmit. I haven't tried other bands etc. and I've been off the air for a few days so don't know if anyone else has reported. tnx Roger
This is a real bug, as I just verified the behavior. I have added it to the bug tracker for resolution. Thanks for the report.0
It's nice to know I'm not the bug this time.
roger 0 -
or the windshield :-)0
- 685 The Flea Market
