Switching between mic and bal cuts the 20db boost off
Dale KB5VE
Dale KB5VE Member ✭✭
edited August 2016 in SmartSDR for Windows
If you have a balanced mic hooked to the rear and a mic such as a headset hooked to the front you can toggle between them but you will loose the 20db boost. It will show it is on but you have to cut it off and back on to make it work.
