Is there a way to run a previous version of SmartSDR?
Tim - W4TME
Administrator, FlexRadio Employee admin
Yes, there is a way. Starting with SmartSDR v0.13.10, you are able to run previous versions of SmartSDR for Windows by just by starting it from the desktop (or Windows Start menu) icon. SmartSDR will automatically recognize that you need to change the firmware version in the radio and will present you with an Upgrade option once you select the radio. Just run the Upgrade process like normal and the radio will revert back to the previous firmware version so you can operate the new version. NOTE: This does not apply to SmartSDR CAT which installs and upgrades with a separate process. You should be new versions of SmartSDR CAT on previous versions of SmartSDR for Windows.
