SmartSDR v3.7.4 and the SmartSDR v3.7.4 Release Notes | SmartSDR v2.12.1 and the SmartSDR v2.12.1 Release Notes
SmartSDR v1.12.1 and the SmartSDR v1.12.1 Release Notes
Power Genius XL Utility v3.8.8 and the Power Genius XL Release Notes v3.8.8
Antenna Genius Utility v4.1.8
Ok,I understand what V0.15.13 doesn't do.....
Bruce B
...So what exactly does it do/offer?
What reason (s) is/are there to actually upgrade?
Bruce
Bruce
The fixes regarding the ATU and compressor slider being operation are my favorites. Below is a list of new features, enhancements and bug fixes in SmartSDR v0.15.13 SmartSDR for Windows: Fixed an intermittent defect that would result in poor opposite sideband image rejection Fixed a defect where the radio would not recover if the Ethernet cable was disconnected Added a feature where the Transmit Control panel is opened by default The 8 kHz EQ control has been activated Added variable TX bandwidth feature in Radio Setup ->Transmit tab Refactored AGC Threshold gain slider values. Default AGC-T = 60 (100 dB) Added feature to disable SmartSDR from connecting to FlexControl in Radio Setup ->Transmit tab Fixed a defect where non-SmartSDR clients that create a slice were automatically assigned to the XVTR antenna port Added a feature to auto close Spectrum Display menu options after use Fixed ATU defect where ATU fails to tune if out of ham band tuning was attempted Fixed ATU defect where operation was erratic when in CW mode Fixed a defect where ATU attempts to tune a high SWR load and reports SUCCESS then goes to BYPASS Fixed a defect where speaker noise was heard on exit Fixed several defects that were responsible for operational instability Improved RX filter sharpness (steeper skirts) Fixed a defect that could result in intermittent loss of audio from the speaker output Fixed a defect there the CW WPM control would not work above 50 WPM Fixed a defect were CW elements would randomly be dropped Added QSK CW keying (low latency switching) FSK line connected to “CW DOT” for keying through the ACC connector Fixed a defect where slices would not tune properly if SmartSDR was expanded to > 4096 pixels Added a feature where the SmartSDR console and forms location is saved on exit Added a feature where GPS data is displayed in Radio Setup ->GPS tab Fixed a defect where Power LED would incorrectly indicate a GPSDO in standby when GPSDO is not installed Fixed a defect where GPSDO was incorrectly indicating it was installed when it was not Fixed a defect were a clicking sound could be heard when GPSDO equipped FLEX-6000s were powered off Fixed a defect where GPSDO equipped FLEX-6000s would show the radio as being Available when the Power LED was green Audio Compression gain slider control is now operational AM is now operational for transmit Performance improvements made to ANF, NR and NB Fixed a defect were the RX would “desense” if NB is enabled Fixed a defect were radios opened up for MARS TX operation would revert to a locked state when the radio was rebooted Fixed a defect where the SmartSDR console could be expanded greater than 3000 pixels wide Fixed a defect where S-Meter was reading 10 dBm high Fixed a defect where intermittent TIMEOUT errors were occurring on GPSDO enabled FLEX-6000s Fixed a defect where AGC would cause a delayed TX->RX transition SmartSDR CAT has been upgraded to version 1.1.5 CAT: Fixed a defect where FLEX-6000 IP address was truncated CAT Fixed a defect in the radio list where FLEX-6000s were not removed when disconnected or closed. CAT: Fixed a defect where SmartSDR CAT would not reconnect properly if the radio was rebooted. CAT: Additional minor defect corrections CAT: Fixed a defect where AsyncSocket server crashed under certain circumstances when a client disconnected0
re: ............... Spectrum Display menu .................... Where is the "Spectrum Display menu" ?0
The Spectrum Display menu window(s) are the windows that pop up when you use the control buttons on the upper left side of the Panadapter. They now 'time out' and close automatically after a set time... saves more clicking... nice little 'feature'.1
This is the menu on the left side of the Panadapter.0
This is a great conversation that's separate from the main topic, so I created a new Praise topic to continue the discussion. Please reference the new topic here: Panadapter auto menu close0
Just made a contact on AM last night, this is another feature new to release v0.15.13.1
- 248 Community Topics
- 488 The Flea Market
- 7.4K Software
- 5.9K SmartSDR for Windows
- 135 SmartSDR for Maestro and M models
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 6.9K FLEX-6000 Signature Series
- 773 Maestro
- 42 FlexControl
- 836 FLEX Series (Legacy) Radios
- 727 Genius Products
- 391 Power Genius XL Amplifier
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 372 Remote Operation (SmartLink)
- 118 Contesting
- 583 Peripherals & Station Integration
- 116 Amateur Radio Interests
- 810 Third-Party Software
