Video Card Recommendations
The bare minimum is two Nvidia GTX 690 dual GPU video cards for QUAD SLI. That should only cost about $2000.
I kid.., honestly anything current that is available from AMD or Nvidia in the $100 range has more than enough horse power to drive it. All modern GPUs can push the DirectX 10 requirements without much issue (so far). I can't say for sure after the other 4 Pan Adapters are turned on for the 6700. I am using a mix of older laptops and computers. New bare **** laptops that come with the Intel HD4000 or HD5000 chipset also work fine. I've used the following: Dell and Asus HD5000 2013 laptops 2011 MacBook Air (HD4000) W7 2010 MacBook Pro (GTX5xxM) 2012 Macbook pro Retina GTX 650M Custom PC with GTX 690 (OVERKILL!! My gaming PC running at 5760x1080 3 screens) Custom PC with GTX 570 Custom PC with 8800GT (very old) For exact links: AMD Chip: http://www.newegg.com/Product/Product.aspx?Item=N82E16814127687 ($69 after rebate) NVidia Chip: http://www.newegg.com/Product/Product.aspx?Item=N82E16814121643 ($89 after rebate) 0 -
If you can do with 1x HDMI and 1x DVI, then there are quite a few options. Something like this would work: AMD 6670: http://www.newegg.com/Product/Product.aspx?Item=N82E16814102988 ($54 after rebate, S/H) I usually look on the low end of the Toms Hardware list as this is usually a decent ****/buck list for 2D performance. This is a good reference for comparing cards too -- see the hierarchy chart toward the end. http://www.tomshardware.com/reviews/gaming-graphics-card-review,3107.html A quick google shows that if you have to have 2x HDMI, it's going to cost over $100.1
The cards I linked for under $100 have 1 HDMI and two DVI. You can easily convert DVI to HDMI. The NV card supports 4 screens at once actually.1
One caution - for video cards offering both HDMI and DVI along with other interfaces. OFTEN the HDMI and DVI are either/or. You can't drive both simultaneously. I am very happy with my 3 monitor setup that uses an AMD Radeon 7000 (built into CPU on motherboard) DVI, VGA and the Display port converted to DVI. Display port converter was cheap. Only caution was the Display port converter must be an active one, NOT passive.0
Thanks, Guys. I will look into them. I looked at Amazon and DVI>HDMI and Display Port > HDMI adapter cables are not that expensive. I may be able to use them. I can't imagine ever using 4 screens at the same time, but 3 is a real possibility. One for the rig, one for logger/contester, and one for Digi &/or internet. But, who knows?0
Buy all of your cables from monoprice.com. Don't be overcharged!1
Is there a good four (4) HDMI output option? 73 Steve K9ZW1
Since DVI is easily converted to HDMI, you shouldn't confine yourself by looking for HDMI out only video cards. Matrox is famous for making multihead solutions. We use them at work in the Network Operation Center for eBay. http://www.matrox.com/graphics/en/products/display_wall/mura_mpx_series/ But it would be easier to add two $100 cards and get 6 screens that way honestly. Just get a few DVI to HDMI converters and have at it.0
Great discussion for reference. Should keep this thread around.0
I would still prefer AMD/ATI graphics cards over nVidia or Intel Graphics. I haven't seen it mentioned here but the current Intel 4000 series graphics adapter built into Haswell CPUs IS NOT COMPATIBLE with SmartSDR. You will see sporadic madness (even though you will hear the radio in your headphones/speakers. I spent hours this week working on a system where nVidia was used but it just wasn't DPC compatible with running a SDR. nVidia makes good stuff but I suspect they are pushing every last molecule of performance out of it with their drivers and thats why they continually seem to introduce bad releases. It seems that you can be on a bad release, then nVidia will fix it and life is loverly, then the next driver release will breaka things agains. This doesn't seem to happen with AMD, their stuff just works. I agree I would not go below the 6600/7600 series of boards however! 731
This is a often searched simple asked question so I thought I would help it out a little bit.
The Flex recommends a Passmark Score of over 500+ number
You can find your video card with the link below.
http://www.videocardbenchmark.net/
73 Jeff
- 419 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 389 FLEX-8000 Signature Series
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
