Can anyone tell me if the new FLEX 6000 Radios will function on Windows 8 with 64 bit Operating syst
W4EY
Yes1
It works for me.0
Thanks for the info. Had to replace a Computer and all that was available local was one with Win 8. I had loaded the SmartSDR's latest program and was sufficient with running the FLEX. Was just wondering if I needed some additonal computer programs to load that was not included with Win8. Some application such as .net Thanks0
Mine works well on a Lenovo Ideacentre K410 with i3 processor & 6GB RAM. I got it at BestBuy online for $399 around Christmas. It has worked well not only with my new Flex-6500 but with a Flex-1500 before it. You don't need a ton of processor to run SmartSDR. But extra horsepower helps when you start running more stuff along with it.0
The primary requirement is video / graphics performance, less so the OS.0
i have a buyer for my 5K as soon as i receive my 6500 and get it up and running, i have all but memorized the manuals for the 6000 series. i am currently running Windows XP which works fine with the 5K however my computer started to lose its mind 3 days ago and i suspect it is on the verge of crashing completely. i had the same problem about 6 weeks after i bought the PC in 2007 and they ended up replacing the whole motherboard (warranty replacement). i've seen a lot of people who have had problems with Windows 8 so i was wondering if i should get Win 7 or Win 8 on the new PC when that time comes.
Don, I use both Win 7 32bit and Win 8.1 64bit without issue. Recommend 8.1 64 bit on a new PC so you can use more than 4GB of RAM. Win 7 32 will let you use older software (DOS). Andrew.0
thanks for the info Andrew. i have no older DOS software so Windows 8.1 looks good.
Don:
I run a Pentium 64 bit Intel Core 3.40Ghz processor with Win 8.1 64Bit Operating system and the FLEX 6500. The Computer memory has been upgraded to 10 Gb.
I have experienced minor issues which appear to be the network glitches. Glitches such as I loose network connection to the FLEX if it has been idle for some periods.
Restarting the computer which established the network resolves the loss of devices on the network. No issues with SmartSDR and DAX. I also, use the latest versions of Fldigi, and HRD. The main modes of operation here are CW and Digital. My only wish is that we had the preprogrammed CW features on the 6500 as we did on the 5000.
Have fun with the new FLEX.
Bill
W4EY
- 117 Aurora
- 323 Shack Infrastructure
- 228 Networking
