SmartSDR v3.7.4 and the SmartSDR v3.7.4 Release Notes | SmartSDR v2.12.1 and the SmartSDR v2.12.1 Release Notes
SmartSDR v1.12.1 and the SmartSDR v1.12.1 Release Notes
Power Genius XL Utility v3.8.8 and the Power Genius XL Release Notes v3.8.8
Antenna Genius Utility v4.1.8
Panadapter doesn't paint unless full screen 0.13.10 and 6700
AG7T - Scott
If the smart sdr window is not full screen the panadapter trace doesn't update. Is this expected? I am running under Windows 8 64-bit. This is with a single slice, I haven't tried multiple slices to see any differences. Scott
I operate all the ltime less than full screen and don't have any problem.. Is this possible a graphics hardware problem on your PC ? AL, K0VM1
I never operate with a full screen and always see the panadapter. I can see 4 slices and 4 panadapters with no problems. Maybe a Win 8 setting somewhere.0
What video card are you using and is it up to date.0
Intel HD Graphics 4600 Driver version 9.18.10.3071 It is built into the latest Intel i7 Haswell and Z87 chipset0
The latest Intel HD4600 driver is 9.18.10.3165 (5/10/2013). Try loading that.0
I updated the driver and it is much better. Usually I keep all the drivers up to date. This particular driver version was not given as part of Windows Update for whatever reason. Thanks, Scott0
DANGER WILL ROBINSON!!!!! I NEVER allow Windows Update to EVER update hardware drivers. Always get your hardware driver updates direct from the manufacturer. They are usually better performers, more up to date and generally work better.0
Let's just say that we agree to disagree on driver updates. I personally have had a lot more problems with drivers I download the way you say. At least there is a quality bar that has to be passed for the drivers downloaded from Windows Update. Thanks, Scott0
Hi Scott, my feelings are generaly with Tim on this, especially if the manufacturer is moderately active in supporting their drivers. I would rather get a fresh new fix from the manufacturer instead of a 6month old qualified driver from Windows Update. I wish you could configure windows update to not replace a newer driver with its downloaded one, but they put so much stock into their signed and tested driver that they will never do that I don't think. Then you get into situations like the current Realtek GBe driver which is a DPC monster and you have to stick with the 2011 version for good performance. Even Realtek is pushing 2012 versioned drivers which do not work. I have no idea where Microsoft is in this problem but I know to stay away.1
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 5.9K SmartSDR for Windows
- 134 SmartSDR for Maestro and M models
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 6.9K FLEX-6000 Signature Series
- 768 Maestro
- 42 FlexControl
- 836 FLEX Series (Legacy) Radios
- 726 Genius Products
- 391 Power Genius XL Amplifier
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 370 Remote Operation (SmartLink)
- 118 Contesting
- 582 Peripherals & Station Integration
- 116 Amateur Radio Interests
- 810 Third-Party Software
