SmartSDR v3.7.4 and the SmartSDR v3.7.4 Release Notes | SmartSDR v2.12.1 and the SmartSDR v2.12.1 Release Notes
SmartSDR v1.12.1 and the SmartSDR v1.12.1 Release Notes
Power Genius XL Utility v3.8.8 and the Power Genius XL Release Notes v3.8.8
Antenna Genius Utility v4.1.8
Slice A Controls not Operative if Slice B is Off Screen
K9DUR
On my 6700, I opened slice A on 3.910 MHz LSB. I then opened slice B on 3.535.MHz CW. If slice B is not visible (off the screen to the left), you cannot do anything with the controls on slice A. You cannot type in a new frequency or open any of the sub-menus. Slice B works normally. If you zoom out so that both slices are visible in the panadapter, then the controls on slice A work again. 73, Ray, K9DUR
Ray I just tried this on my FLEX-6700 and was unable to make this happen. I brought up two slices, panned until B was off the screen and the off screen indicator showed up. Then I tried tuning A, opening the menus and typing in a new frequency. All of these things worked. I'm running development code, but I don't think that we've done anything that would change this behavior recently. Is anyone else seeing this? Steve0
It happened to me once, right after I read Ray's notice. Then I went back and forth between A & B and slid the pan back and forth and it started working again. I don't remember what I had been **** before the malfunction happened. I have not been able to reproduce it yet.0
Correct that... I just had the rig on 40 meters with a single pan & slice. I changed to 80 at 3.910 on A and added B at 3.535 Before I dragged the display anywhere, I tried to change volume and mode and got nothing. After moving the display I could access controls.0
Steve, My exact procedure is: 1. Turn on power supply to 6700. 2. Turn on 6700 & wait until it boots completely.. 3. Start SmartSDR CAT. 4. Start SmartSDR. Slice A is at default frequency/mode of 14.100 MHz USB. 5. Change band to 80m.. Slice A is at 3.800 MHz LSB. 6. Type in new Slice A frequency of 3.910 MHz. 7. Click on +RX. Slice B is at 3.910 MHz LSB. 8. Type in new Slice B frequency of 3.535.MHz. 9. Change Slice B mode to CW. 10. Double-click on A> to center panadapter on Slice A. 11. At this point none of the Slice A controls work. Clicking on the speaker icon, DSP, or LSB has no effect. Also, clicking in the frequency display area to highlight it has no effect. 12. Double-click on <B to center panadapter on Slice B. All of the Slice B controls work. 13. Zoom out until both slices are visible on the panadapter. 14. At this point, all of the Slice A controls work again. NOTE: If one of the sub-menus is open on Slice A before you open Slice B, when you come back to Slice A, that sub-menu's controls work, but you cannot switch to a different sub-menu or type in a new frequency. 73, Ray, K9DUR0
I have been able to repeat this at will. Rig is 6500, 1.0 version, open 2 slices with B out of view. Go to B, can change sliders (volume, AGC-T), freq, etc. Double click on slice A arrow to move back to that slice, none of the A sliders work, can't change the freq as well. Increase bandwidth such that both slices on screen all is normal.0
This issue will be addressed in SmartSDR v1.10
- 250 Community Topics
- 488 The Flea Market
- 7.4K Software
- 5.9K SmartSDR for Windows
- 135 SmartSDR for Maestro and M models
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 6.9K FLEX-6000 Signature Series
- 773 Maestro
- 42 FlexControl
- 836 FLEX Series (Legacy) Radios
- 728 Genius Products
- 392 Power Genius XL Amplifier
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 373 Remote Operation (SmartLink)
- 118 Contesting
- 583 Peripherals & Station Integration
- 116 Amateur Radio Interests
- 810 Third-Party Software
