Input power and Audio Question
W0QKL
Two Questions. 1.) What is the power drain in TX mode? The power meter reads 100+ watts and the amp meter on the Astron RS-35M only shows about 12 Amps. 2.) I have the Heil PR781 Mic with 3 pin XLR to TRS Male plugged into the balanced Audio input in the back of the unit do I need the ACC ON or the Bias ON? I also can see no difference between the BAL and LINE setting.
Robert, 1) My power supply read about 20 amps at 100watts out in tune.. Which is about what all 100 watt out rigs should read.. You might have a metering problem with the astron ? My astrons have all had suspect amp meter readings. 2) You do not need to have ACC on to use the BAL or LINE inputs.. ACC ON is if your using the line in on the ACC Connector. Can't help with the rest of your question. AL, K0VM0
- 419 Community Topics
- 718 The Flea Market
- 226 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 389 FLEX-8000 Signature Series
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
