Unable to set com ports
Dale Belcher
I am a new user trying to configure my Flex1500 for jt-65/ jt9. I can't set the ports in powersdr. It just says "none". I have Com0Com installed, vac installed and can receive but not transmit. rig does transmit cw .Also, anyway to feed the audio to the speakers in the laptop without cables? Pulling hair on this.
Dale, Got your pairs setup in com0com? Maybe. 6 to 16, 7 to 17?? After you set up the virtual pairs , then assign one end to PSDR CAT control tab. then the other end in your program. If you just set up the virtual ports then close and restart PSDR. For the virtual ports to show up, you have to manually select the correct port. Hope this helpso0
Dale, The FlexRadio Community is currently providing only support for the FLEX-6000 and SmartSDR,as there are existing Internet based support services for PowerSDR and the FLEX Series SDRs. I recommend that you check out the Knowledge Base or submit a HelpDesk Support request (http://helpdesk.flexradio.com). I have converted it to a HelpDesk support ticket and closed this topic.0
