Filter width displayed is not correct
Michael - N5TGL
Noticed this behavior this evening. I was on 40m, LSB. Switched to CW. Selected 50 hz filter. Switched back to LSB using the dropdown. Filter width highlighted is the blue button at 1.6k, but actual filter shown in the panadapter is 2.7k, right where I left it. If I click on 2.7K, it highlights the 2.7K button with no difference in audio. (which you'd expect if you were truly going from 1.6k to 2.7k) If I go through the same process and this time click on the 1.6K that is highlighted, you can see the filter narrow and hear the audio change, which it shouldn't if it was truly set at 1.6k like the blue highlight indicates. Summary: If you switch to 50 hz filter in CW, switching back to LSB will display a filter setting of 1.6k when it actually is 2.7k.
2
This is a known and previously reported defect. It will be addressed in a future version of SmartSDR. Thanks for the report.1
- 685 The Flea Market
