Signalink and Aux Port
Travis Best
Using a signalink USB with the Aux Port with audio from SignaLink Turned Up 100% its still not enough audio to really drive the radio
Have you tried the +20db button (SSDR) and/or the "extra output" jumper in the Signalink? I'm using the mic and phones connectors here with good results, if the AUX doesn't play well enough for you. Good luck!0
Your SignalLink output is set for a microphone input, isn't there an adjustment internally to increase the output level? Otherwise, you could use an external mixer or preamp to increase the level. Our aux input requires line levels.0
Thank you moving the jumper on the signalink resolved the issue.0
