SmartSDR v3.7.4 and the SmartSDR v3.7.4 Release Notes | SmartSDR v2.12.1 and the SmartSDR v2.12.1 Release Notes
SmartSDR v1.12.1 and the SmartSDR v1.12.1 Release Notes
Power Genius XL Utility v3.8.8 and the Power Genius XL Release Notes v3.8.8
Antenna Genius Utility v4.1.8
ANT assign change with RF gain selection
Sergey R5AU
HI, i have a issue, ex: you are operating with ANT= ANT1, changing it on RX A, and starting change RF gain - input signal will reassign into the ANT2, try mentioned manipulation again - signal came back into the ANT1 circuit - ?
Sergety, If i understand your method correctly, then I can not duplicate it.. What radio are you using? What version of Software ? Can you repeat the fault after rebooting the radio and restarting the software ? ( I'm using 6500 and 0.13.10 software. ) AL, K0VM0
Hi AL, i am was wrong, following manipulation valid: You are RX on "ANT1", switch to the "RX A" next switch to the "ANT1" and you lost signal on "ANT1", but signal still exist on "ANT2". To come back with signal on ANT1->switch to the "RX B" and now back to the "ANT 1" - signal on "ANT 1"0
i am sorry, here is 6700 + GPSDO and 0.13.100
Maybe it's a 6700 problem, I can not reporduce on my 6500 / 0.13.10... Can anyone with a 6700 duplicate ? AL, K0VM0
Sergey, I can now reporduce it... ANT1>ANT2>RXA>ANT2 received is listening on ANT1 .. It might be different on the 6700... I guess I don't every loss signal on ANT1 but do have it on ANT when I shouldn't. AL, K0VM0
There are numerous issues related to antenna switching (see the caveats in the release notes for SmartSDR v0.13.10). This is a known issue and is slated to be fixed in a future version of SmartSDR.0
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 5.9K SmartSDR for Windows
- 134 SmartSDR for Maestro and M models
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 6.9K FLEX-6000 Signature Series
- 768 Maestro
- 42 FlexControl
- 836 FLEX Series (Legacy) Radios
- 726 Genius Products
- 391 Power Genius XL Amplifier
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 370 Remote Operation (SmartLink)
- 118 Contesting
- 583 Peripherals & Station Integration
- 116 Amateur Radio Interests
- 810 Third-Party Software
