Line 1 Out Second Slice Muting?
Ed, K0KC
I use Line 1 Out for the digital modes. The WSJT-X software that I use for JT9 and JT65 includes a split option that allows both modes to be worked with the same GUI. Split mode with the Flex-6700 requires that a second slice be launched. In this case, I assume that the received audio from both slices is present in the Line 1 Out signal. Since Slice B is only used for transmit with WSJT-X, I want to mute any audio from that slice. Some of the documentation (on this Community site) makes reference to a "Mixer" which I assume would allow me to control the audio output from any slice. I also assume that the slice mute available in the slice control panel only mutes audio to the headphones and/or speaker. My question is how does one access this mixer in 0.13.10? If it is not accessible now, when is its implementation planned?
Click on the speaker symbol, then the speaker symbol next to the slider in the slice control panel. This will toggle the audio output including line 1 for that particular slice. Just like you, I do this to mute the audio on the Tx split.0
