Rx slice freezes with when SmartSDR window > 3000 pixels
Bill - K7UOP
Bill - K7UOP Member
edited February 2019 in SmartSDR for Windows
Rx slice freezes with when SmartSDR window > approx. 3000 pixels. Not really a problem, just FYI. I have 3 monitors hooked together for 6112x1080 resolution (for flight sim). If I increase size of SmartSDR window greater than half way, the Rx Slice freezes (cant move it) but the signals and freq labels at bottom continue to scroll Ok. Reducing the size, it starts working again. I don't plan to use SmartSDR this way, just thought it was curious and wanted to let you know.
  • George KF2T
    George KF2T Member ✭✭✭
    Do not have this experience with two 1920x1080 monitors and SSDR spanning both completely. I do notice the CPU load increases with more video demands, and that I get audio clicks/dropouts at some high FPS and large display settings.
  • Tim K8XS
    Tim K8XS Member
    edited August 2013
    I noticed weird behavior if I stretched it across two screens. Each screen is 2560 x 1600. So two screens wide would be about 5120. It would stretch but leave about 25% of the window on the right side unpopulated. I was trying to display 50.00 through 50.130 across the two displays. If I reduced the size by dragging the right side to the left, everything would display correctly. I could then stretch out the display again as long as I didn't try to scroll the window. This is not a normal mode of operation for me. I could possibly be exceeding some preset array size? Just info for the back burner.
    edited March 2017
    I have submitted this bug report to our development tram for further investigation. Thanks for the report.
