Filter settings button in slice control panel not updating by changes via CAT
Dave - WB5NHL
When changing the filter selection via CAT command, the filter changes (both the width of line in display and filter value at top of slice Rx control panel) but the display button in the slice Rx control panel does not change.
Dave,
I have entered this problem report into the developer's bug tracker for additional investigation. Thanks for the bug report.0 -
Tim, pls also add as report - not all buttons(sliders) on slice TX control panel(with EQ,MIC,SWR..) are response with CAT commands0
This issue has been addressed in SmartSDR v0.16.x and greater0
- 688 The Flea Market
- 105 Aurora
