Will there be an SDK for the Mac's? I long for support for Apple products!
Reggie-k6xr
There is a TCP/UDP/IP API which can be used by OSX. There is one developer who has created a class library for accessing the radio via Objective-C under iOS (Stu, K6TU. See this thread: http://gsfn.us/t/470ye) I suspect that this model code would port easily to OSX. You might contact Stu directly or you can send me a note if you are interested in starting over with the TCP/UDP/IP API. A real SDK, which I judge to be the API plus a lot of documentation and sample code, is a ways off. Steve0
I will wait for the future.0
