Digital Mode Transmission Distortion
Ed, K0KC
Ed, K0KC Member ✭✭
edited February 2019 in FLEX-6000 Signature Series
I recently constructed a cable to put my Flex-6700 on the digital modes with my Tigertronics SignalLink USB modem. I have been able to make a number of JT65 and JT9 contacts with this setup, but have noted when transmitting, the waveform (including the baseline) on the panadapters will randomly jump perhaps 30 or 40 dB and then quickly returns to normal. I have not noted a glitch in output power when this problem occurs. This anomaly probably occurs at least once per 50 second transmission and lasts less than one second. It appears similar to what one would see from a lightening strike somewhere nearby when receiving. In this case, however, there is no lightening and it is the transmitted waveform that I am viewing rather than the received one. SSDR 0.12.17 running under Win 7/32, DIGIU mode.
  • George KF2T
    George KF2T Member ✭✭✭
    Same issue which does not appear to affect transmission.
    edited March 2017
    That is the question I had too. Is this just a visual anomaly or is it being transmitted as RF. I suspect it is just a visual FFT display anomaly. Ed can you verify this?
  • Ed, K0KC
    Ed, K0KC Member ✭✭
    edited September 2017
    Tim, I suspect that is a visual anomaly. I never listen to JT65 or JT9 signals off the air or via a monitor, but yesterday, I did engage the monitor and there was no clicking, noise or other indication that the RF signal was affected by the display jumping around. If I do not hear anything in the monitor, I think that it is a good assumption that the RF is clean, especially since I also observed an external power meter and could not see an output power "glitch". I have had no problems making contacts either.
    edited March 2017
    That is what I suspected. We will be doing some things to clean up the spectrum display on TX in future versions of SmartSDR.
  • Ed, K0KC
    Ed, K0KC Member ✭✭
    Another data point...when I use the tune button in WSJT-X (transmits a single tone), the display jumps around. It did not seem to do that when I used the tune button in SSDR.
    edited December 2016
    This is just another manifestation of the FFT display issue I mentioned above.
  • George KF2T
    Seems much better in 0.13.10
  • Ed, K0KC
    Ed, K0KC Member ✭✭
    I agree...seems much better in 0.13.10.
