DB scale inconsistencies between full screen and partial screen
Ken K7YR
DB scale inconsistencies on my 6700 ........ An opportunity (1) Select any band slice....... (2) Select "Not a full screen display"........ (3) Note vertical DB scale lines........Appear OK (4) Select full screen display......... (5) Go back to "Not a full screen display"....... (6) Note added vertical DB scale lines between the scaled lines (7) Left click on db scale band and slightly move scale up/down (8) Scale lines correct themselves..... This is repeatable Ken K7YR
2
Ken, Yep, we know about this display "feature". It is on the defect list to be addressed. Thank you for posting a reproducible procedure. That helps the development so much in finding the root cause.0
- 105 Aurora
