Tuning Flex 6400
jerrylord
jerrylord Member, Unconfirmed
When I tune my 6400 to my Ldg 100 I do get a low SWR. However, the panadapter shows what I call splatter. I have read this is normal. Is it normal?
    Hi Jerry, yes this is normal. You cannot look at the panadapter that you are transmitting from to have any idea of your signal quality.
    Ken Wells, NM9P has some excellent YouTube videos on using a second panadapter and Full Duplex (FDX) to look at your transmitted signal properly.
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    The panadapter on transmit just shows what "leaks" into the receiver before the normal output filtering. Another option is listening on another radio using WEBsdr and listening on another radio or PC.
