Are the originally provided Microphone Profiles available to be downloaded?
I would like to download the microphone profiles that were part of the initial SmartSDR installation. I deleted most of them when I did my setup and kept only the ones I needed at the time. Is there a place where that can be downloaded and kept available to be installed as additional ones are needed?
  • Erik Carling EI4KF
    No there is not but when you reset the radio the default mic profiles will be restored. Once you have done that, export them somewhere using the profile Manager.
