Dummy Load setup?
Jim NO0B
Member ✭
I have antenna 8 connected to the dummy load. In the Antenna Settings it is Custom 1 and has checks in None RX and RX and TX on the line for Custom 1. Should I check RX and TX for every band the radio can tune to, or continue to leave them blank?
Note, unless you plan on being able to select antennas when no Flex is connected (manual mode), you can uncheck the None RX box for each antenna port.
By doing that, Only available antennas for a band will display in the AG app.
73 Dave wo2x
